My '77 is a little different than most. The engine is a 351W with an OE 302 Bronco pan modified to work on a 351. I had a 351 conversion pan and dipstick before a frame off, but the tube kinked when the shop bent it without a tubing bender. I couldn't find a new one of the same type. So I got a 351 tube from BG that is longer than the dipstick. They told me these were made to be used with the 351 conversion (5.8 Panther body dipstick) that is shorter than the tube. I can cut the tube shorter at the top if I know how far the tip needs to extend past the bottom of the tube to accurately measure the depth of oil in the pan. The only reference point on the tube, that I think would work, is the ridge that the 3/8" compression nut bears against. What I need is the distance from the tip of the fully inserted dipstick to the bottom of that ridge.
