86caprirs
I just installed the 79 disc brake setup on my 74 Bronco. What do I need to connect the brake caliper hoses to the 74 hard brake lines? Does the caliper flex hose unbolt from the original 79 Bronco brake line where the bracket bolts to the axle tube?
I also have a piece missing from the front brakes. It is what connects the axle to the rotor hub for 4x4. Is this part interchangeable between 79- 96 F-150's/Bronco's?
And one last quick question. Before i took the brakes apart, i pushes on the brake pedal and noticed that the rear wheel cyl did not move. Could it bee as simple as siezed wheel cyl in the rear or a proportioning valve issue?
