csmith441
I know this has been talked about and discussed more times than one can count... Sorry.
I torqued the spindle washer/nut with the nipple on it to 60ft lbs (then backed off 1/4 turn), then get the spacer with the holes on, and then torqued the lock washer on to 90 ft lbs.
When I had it at just 60 with the first threaded spindle washer/nut the wheel would rotate smoothly with some effort. Once I got the lock washer torqued it take quite a bit more effort to rotate the assembly.
How much effort should it take to rotate the assembly?
