Sorry to disagree with you but the BCB air is designed to fit a early bronco only. We use some off the shelf parts like dryer, bulk head connectors some control knobs and compressor but most is designed for the EB like condenser made just for the EB, evaporator made for the firewall, mounting brackets to fit the compressor to the small block and condenser shield.There is no eB-specific A/C system; they're generic, so since NOT all vehicles have a fresh-air supply in the location & shape of the eB's, the retrofit A/C systems don't use it.
For defrost, fresh air is always drier than inside air (by relative humidity; not necessarily by absolute humidity).
When I do AC am I going to need the original ductwork or does vintage air or BCB use something else?
Chuck, my question is, can I alter the firewall to do away with the air intake on the passenger side that comes out at the kick panel?
Yes. I have seen several threads here where that was done specifically to make room for the AC unit. I think they were running the Vintage Air Gen 4 units.
BD99 - you mean "yes", you've seen people flatten out the cowl?
Good to know. ;D So did you design the inside box specifically to draw fresh air from the original RH hood vent? Are there pics of these parts on your site? Can you post links to them, or the photos here?...the BCB air is designed to fit a early bronco only. ...evaporator made for the firewall...
I don't understand the wink. %) Why would you think I'm familiar with it? ?:?I'm pretty sure you are familiar with Chucks A/C unit.....![]()
Why would you think that? It's only 1 more mode door. If the evaporator housing is already designed to fit the eB firewall, the amount of additional plastic to make it reach the fresh-air hole would be negligible. I was on the verge of adding that to the VA system in Frank's truck when he had me sell it for him....fresh air ducting...would likely add a lot of cost to the unit.
It did not cross my mind that places like fl. could have 100% humidity and 100 degrees. But I am not sure that fresh air vents will help there anyway.
Not really. Letting fresh, warm, damp air in during A/C will cause the cabin to be warm & damp. It will take a long time for that heat to circulate through the cab back to the A/C to be dehumidified & cooled. Letting cold air in during heating isn't quite as bad, but it still makes the cabin feel cold. But if it comes in through the HVAC to be processed FIRST, the cab will be a more-comfortable temperature, and feel drier (whether A/C or heat).There is a fresh air duct on the drivers side that will get fresh air inside. Not quit the same but close.
As someone who has studied mechanical engineering & physics: if there's condensation INSIDE the glass, fresh air is absolutely drier than recirculate, and will defog the glass MUCH faster than recirculate. Always, in any climate, at any temperature, even if it's raining.as a professional mechanical engineer who does HVAC design in FL:
Recirculate and close off the OA vent. Unless your cabin is perfectly sealed and you're going to be in there for over an hour, do not worry about fresh/outside air.
