The bracket is welded on, much like a spring perch on the rear axle. The bracket, bushing and sway bar is held on by the U bolt. See picture #2.
So i've been meaning to ask this and this thread just reminded me..
I've sourced all of the factory sway bar parts to add to my '74.. but some questions:
1.) does the passenger side perch really need to be welded on? I've already painted my axle and the perch. From what i can tell, it's almost like the driver side that simply allows the u-bolt to hold it to the axle tightly? I can't find any reason why I can't simply use the loose perch + u-bolt on the passenger side like the driver side? And why did ford weld one side and not the other?
2.) how important are the square holes on the radius arms to run the connecting bolts through? I didn't realize, but I have a one '77 radius arm (was likely replaced by the PO) and one without. As far as I can tell, the radius arm bracket mounts both above and below the arm, then a bolt through the middle. I've also got my radius arms powdercoated already and debating if I really need to drill a hole through the one in addition to the bolts above and below.
I'm sure both welding and drilling would potentially make the sway bar more 'factory-like' and effective...but the real question is it worth it for me at this point?
