Do I need a kick down linkage C4?
Kegger
belton,Texas
76 nailed it, I didn't have a kick down with mine for like 10 years used a locker cable set up, about 1 hrs to intstall and with my stroker, ITS a BLAST. great up grade. Yea you can manually come down, but its a nice feature just to put your foot on it,, If your motor large enough you can get by without. c-4 have a tendency to come out the hole in 2nd.
Bronk74
North Las Vegas
It looks like I have room to install one on the Lokar bracket but I don't think I have a place on my Edelbrock carb linkage unless some one can point it out to me in the pictures I posted.
How about the mount on the c-4 pic?
01Dudley
Knoxville
The C-4 kickdown bracket will attach to the current LOKAR carb bracket that you have. The cable will attach were you have the return spring mounted and the kickdown will come with a little teardrop shaped bracket that will allow you to put the return spring back on. Hopefully this picture will better explain
OklahomaBroncoB
Bixby Oklahoma
Hey all, I know this is resurrecting the thread but great info in here. Mine kept shifting hard from 3-2 in town so I finally decided to crawl underneath it to check the vacuum line, low and behold there was a kickdown rod but not hooked up. Hooked it up and man what a difference ! My issue now is it sticks in 2nd gear till about 45-50 mph so how do I adjust this? Jsyk it would always shift to 3rd at about 35 before I hooked it up.
WheelHorse
Where the rod hooks to the carb, on the mini bell crank, there should be an adjustment screw. Back it out to lower the rpm shift point.
I believe when I hammer mine, first gear will come out around 45-50 mph. 3.50 cogs, stock tires.
