UPDATE: I discovered the PO did not put bolts back in the windshield, on both sides. That allowed/caused the top to push the windshield forward, causing the uneven gap in the pics between the windshield and the top door/window frame. I knew it had to be something like that since it was the same on both sides. The reason I didn’t notice it is because my dash is covered. the PO had it done. They didn’t I stall bolts before covering it. They were using the hardtop to hold the windshield in place. Now that I have the windshield tightened at the correct angle, the top is too far forward. The rails that slide into the vertical pillars and the rear corners in the hardtop will not allow the top to be moved to the rear. Has anyone else seen this before. I basically need the top to go back about 1/2” to make it line up with the windshield. Currently the front of the top sticks out too far past the windshield.
