Door Hinge Backing Plate Replacement
bossnoc
Fishing Creek
Good evening,
I'm new to this forum but not new to Bronco's (first one purchased in 1981) and I'm also a Mustang guy, restoring a 1969 CJ Mach 1.
I've heard two schools of thought on replacing door hinge backing plates, cut the plate around the plates or cut the kick panel. My 68 Bronco is amazingly rust free and cutting it isn't something I want to do, but they need replacing in order to add doors.
I've read several old post on here, but the picture links didn't work anymore. Does anyone have any ideas and pictures to go along with them?
Kevin Kelly
BigBlueBronco71
Santa Maria, CA
I just did this and decided to cut the back of the door post, my thinking is the fender covers this and no-one will ever see it, if you want you can still blend the welds in nice and repaint so it looks like nothing happend
If you're absolutely opposed to cutting you can try to very carefully drill and tap the current backing plate but its very difficult IMO
I cut a little more than necessary since I wasn't sure how the plates were actually mounted in there
B
bossnoc
Fishing Creek
Thanks for sharing that makes sense and since I have the fenders off, replacing them it is easy.
Thanks again
KK
jckkys
The door posts are open at the bottom on my rust free Az. '68. Look behind the front wheel and you'll see the front sheet metal is cut away at the bottom of the door post giving you plenty of room to replace backing plates. The later years they closed up the bottom.
B
bossnoc
Fishing Creek
I see an opening at the bottom, but my big meat hooks won't fit in there... I'll try to share a picture.
Do you have any pictures?
KK
Rustytruck
If your plates are in place and not falling down the door. I would slide them back in place and wedge them in place with an awl or screwdriver between the plate and the door jamb. Then I would drill a #7 hole through the door jamb and the mounting plate and tap this hole with a 1/4-20 tap. Then I would put in a 1/4-20 bolt and cinch it tight. Using a small dremel type grinder I would then grind flush the broken bolts. Center mark them and then drill and tap new bolt holes. That way you save the integrity of the door jamb and your not fixing something that isnt broken. The extra hole you drilled and tapped will be behind the hinge not seen by anyone once you remount the door. If your plates dropped then your stuck hacking away.
jckkys
I guess I never tried doing more than oiling and chasing the threads in the plates, but I can see them looking up from below and a little ingenuity could make a tool to replace them.
DaveLev
Mine were done previously by cutting slot on inside of door jam area near kick panel. Not the prettiest, but the assumption was a kick panel speaker would go there eventually.
