Baja71
- Oct 16, 2004
- 2,908
Has anyone ever successfully redrilled and sleeved the hinges while still on the Bronco?
It seems to me that the most difficult part of this job is removing the factory hinges without damage. In looking at the doors, it seems that with a long enough bit you can drill the top hinge from the top, and the bottom hinge from below, then tap in the inserts. Is it also possible to tap out the factory pins from below, while still installed, without damaging anything?
Please give me some feedback on this procedure, pro or con.
thanks!
thanks!
