door inserts
77broncoAR
Ibought new inserts and need to find out the easiest way to install them? I am trying to find on the net but cant find it anywhere.
gearida
Newburgh, IN
I purchased small rive-nuts... drill a small hole insert a something that looks like a sleeve with threads on the inside, use a proper installation tool that will expand the sleeve into the hole and you have a anchor for screwing into. Have yet to finish, so I don't have pictures.
Gas Pig
Ford just used size 10 pan head sheet metal screws, on the metal backing plates and on the fiberglass they used a size 10 oval head sheet metal about 2" long. You can get all the needed hardware in stainless steel at Lowes.
JLBachs
Got mine used - the people I bought them from gave me their sheetmetal screws and these cool little caps that snap over the screw heads - paint them body color and they're invisible from 10' or so.
