So I've been looking for crappy used doors to essentially make softdoor inserts out of real doors, but prices on even the shittiest steel doors makes it kinda silly for an experiment and still have a ton of work to do, mostly guessing, cutting, fitting, cutting, re-fitting, etc. And then I still have fix the rust issues.
Honestly I can't believe people have been putting up with the traditional door insert for almost 60 years now. Hear me out! Think of the advantages of having a normal door in lieu of a traditional insert.
- using the new Lift off hinges, easily swap b/t regular doors and the "inserts". even traditional hinges wouldn't be bad.
- no swapping to inserts (say minimum 4hrs if you swap spring+fall)
- No deciding on 1 piece or 2 piece at the time of purchase
- No scratching paint (priceless)
- so body Weather stripping stays in place (better sealing), and no having to seal the inserts. There's a cost to all of that and total effing hassle.
- No removing and realign of hinges (depending on how particular you are, that's a disaster)
- No drilling holes in the body (priceless)
- And finally, if you need extra room to climb or load something in the back, you just open the door. (priceless)
- sure, rigidity could be a challenge, but between the frequency of opening/closing and the purpose it serves, I don't see a need to make it as rigid as a normal door anyways (there's no window frames, or anything else).
It occurred to me that Bronco Design already offers a full door (so the hinges+latching+everything else sorted out), and they already offer a door insert (so they have the softdoor dimensions sorted out too). So I can't imagine it would be too hard to meld the two. Point being I emailed them recently, and I'd hope that the bronco world would welcome this, and that Bronco Design is around and would entertain bringing it to market.
