Ark Bigfoot
- Jan 22, 2020
- 114
1972 Bronco. I was having issues raising and lowering my windows. Took off the door panel and discovered the window spring was full of dust and crude. Cleaned the spring and works as it should. Now need to replace the mositure/dust barrier. What are recommendations for the barrier and adhesive? Also having to replace the masonite backing panel board. Is there an easy way to attach the panel board back to the door. It had the "x" looking wire panel clips. The issue I have with the clips, it is almost impossible to remove the panel once the panel is installed. The clips are so strong and don't want to release.
