I have a dec 65 build 66 bronco, and purchased the seal replacement kit from Nick (northeast) did all the windows and doors and heater etc., and since all the door seals were completely GONE on my truck I needed a little guidance in installing them. After i had installed his seals, noticed my hinge pins were so shot that the drivers upper right frame was hitting the B pillar and caused steel in the window frame to tear on 3 of the 4 sides... re-pinned and bushed the doors with bushings and pins from WH. Needless to say, installed, pinned, and glued the door seals from NECF and after adjusting shims in hinges, the doors close nice and solid... no rattle no wiggle no force, really nice soft seals, plastic pins line up with all the holes, i used Gorilla Glue in corners of the seals and flat surface, but i am so pleased with the door seals from nick. After i installed the upper door seal i realized i needed to remove the roof to work on the windshield so i had to cut the upper seal at the windshield joint to be able to remove the roof and hinge the windshield down, but some urethane black sealant in the cracks made it watertight again. Drivers door still has the window frame out till i get some welding done near the wing, but the passenger door has as solid a "thunk" as ANY of my Audi's... i'm very pleased with the door seals from NECF... a little silicone spray to keep things soft, supple, and slippery, and the doors close beautifully...
c
