Tucknkitty
Newbie
- Nov 9, 2013
- 54
Ok-
I've read several times about how important keeping the drag link and track bar parallel and as close to the same length as possible. Looking for some experience with certain setups
1. I have used the wh 3way for the 77 / with the draglink matching as closely as possible - worked great till I went with meatier tires and then had a hard time sourcing replacement ends. I was running 13.5" wide Toyo MTRs 35" (I realize it's also the wide tire driving differently)
2. I now have a variant of the chevy one ton and the drag link is obviously longer and I do notice the steering difference and tie rod rock. I have the cure and it helps but it's not perfect. Been on for about a year and it's time to replace soon. (I drive my rig a lot and take long road trips)
So -
What have you guys experienced? I have always liked the Clydesdale set up from WH - if you need change an end you just replace a cartridge not an entire TRE - meaning no need to realign (which is easy but still) but does this set up still have the tie rod roll? How much longer than the track bar is it? How are the cartridges - sturdy?
I don't want to change over to heim but do like the saddle in the BCB setup.
The chevy Tre setup I have is made so I don't have to ream my knuckles - extreme custom fab- good set up, still have to source tre from his shop. Are the larger chevy Tres stronger and less roll resistant? Worth reaming my knuckes?.
Some of this may be for posterity - my truck drives really good but I do notice the rolling and the extra length of the drag link vs trackbar. I'm gonna replace the ends and trackbar bushings this fall - roughly 10k miles or so between changes. Any suggestions? Is clydesdale worth the cost? Do I go back to the WH 3way again and get used to keeping extra ends on hand? Stay with the chevy setup - it's great when I first get them but they do wear.
Notes:
5-6 deg pos caster
28psi tire pressure
Roughly 1 degree ish camber both sides
3.5" lift and WH springs with bilstien 7100s
No wander / minimal bumpsteer when slamming the brakes (I believe it's the draglink length)
I may just be a perfectionist and this is as good as a lifted short wheel base truck will drive. I replace ends and it's tight steering with positive feel - it goes away as they wear. Is there a better setup out there??
So -
Notes:
5-6 deg pos caster
28psi tire pressure
