And remember too, if your angle is off and you do need those shims (more and more common these days by the way) you're not going to need as long a shaft. As the pinion climbs up, the distance to the t-case get's shorter. By quite a bit.
So at the very least, make sure your pinion angle is correct before ordering a driveshaft by length.
