planewrench
With just a 3 1/2" Duff's lift I wound up with some pretty extreme driveline angles. After cutting up and rewelding the front axle and shimming the rear axle with wedges at the spring pads most things are under control. What remains is a fairly severe angle at the double cardan joint at the rear of the transfer case. I've dropped the crossmember about as far as it can go, but that's not enough. Any ideas other than a high pinion rear? (Can't afford that). Thanks in advance, George.
