Driver side rear freeze plug replacment?
Bronco Sport
NW Portland, Oregon
:mad: Has anyone ever replaced a driver side rear head freeze plug without pulling the motor or head? All of the freeze plugs were replaced when the motor was rebuilt about 5 years ago. It's leaking around the bottom part of the plug and it's getting a lot worse.
I've looked at what it would take to cut a small hole in the fire wall but its right where the fire wall curves and it would be way up under the dash. So that's not really an option, or is it?
Second option I'm leaning towards is pulling the valve cover off and seeing if I can get at it that way. I might be able to get a screw driver in there to pull it and then use one of the rubber replacements.
Am I missing any other ways to go about this besides the obvious, or is that about it?
72_EB
66to77
Been there done that.
Yeah, cutting the hole in the firewall is not going to work. You won't want to really do that anyway, would you? There no room to do it and punch it in anyway, that I noticed.
Rubber expandable freeze plugs pop out. Don't use them! I had this happen to me twice. Once luckily close to home, the other time under the truck when it has just gotten warmed up! :eek: I don't think I've moved that fast since. Good reminder to you to borrow a pressure tester once you get them in to make sure they are actually in!
But Dorman does make a brass expandable plug that is pretty good. You should be able to like you said get a screw driver back there, pop the old one in and get it out with a thin pliers or something, then get the new brass expandable up there, popped in and tighten it out. It's not going to be done without cursing and beers though. I remember it wasn't easy. I can't remember if I had the best working room from above or below. You'll have to see.
I think I have one of those brass expandable plugs laying around too, so I can snap a picture so you know what you are looking for. But anyway, these lasted a while for me. At least until I did my heads and popped in good brass solid plugs.
Good luck with it! I don't envy you right now!
72_EB
66to77
Here's the Dorman part # of the brass expandable.
Here's what it looks like.
Here's that useless rubber one to stay away from!
A good Napa should have them, but I got mine at a good ma and pa parts place that has them around me. If you just need one, I probably have a spare for ya, but you might want to just buy at least 3 or so at the parts place. If you've ever done freeze plugs before you know, that you can screw them up putting them in (especially in the spot you are trying to do). I like to have one in the glovebox too, just in case. Good Luck, Sport!
Bronco Sport
Bronco Sport
NW Portland, Oregon
Thanks a lot for the great pictures!
Is the 1 1/2" the right size for a 302 head, and are they different between 289 heads vs. 302?
Thanks again for the input! I plan to give it a try soon, if I can get it out I guess I'll pull the head and do it right. Also if I do that I'll do both heads with new plugs and replace the head gaskets too. What a nightmare!
72_EB
66to77
95% sure they are both 1 1/2. At least on my 302 they 1 1/2 in both the block and the head. Standard 289 should be the same.
Yeah, if you do those head gaskets, pop in some good brass ones freeze plugs all around then slap some new valve seals in while you have the heads off too. ;D
mtkawboy
Billings Mt
I just looked at mine and its really tight. I think you could use a 90 degree drill and a hole saw and maybe use a freezeplug installation tool & do it then pop rivet a patch in. Going to be a bear, might be easier to pull the heads and change them all at the same time. If one goes the others wont be far behind.
