Drivers Floor Pan Replacement Question
BGBronco
N A S H V I L L E
Tennessee
First time replacing a floorpan. I bought the TBP 1 piece drivers side replacement and I have a fitment question.
I have most of the old one cut out. The outside edge / left side of the new pan has about a 1" lip that runs the full length of the pan.
I'm trying to figure out if this lip needs to overlap the small rail on the upper part of the rocker and I cut out a section for the crossmember or if I remove the lip all the way to the crossmember.
Sorry for the piss poor description.
Thank you!
Attac
You kinda have to figure out what is good metal on the old stuff and you can trim to fit the new to it. Take a few pics of crossmember where it attaches to inner rocker and post them.
Chuck
Attac
The cross member is actually held in place with the floorpan and the inner rocker so if those are good you can trim to fit. If it is rotted there you will have to get it where you can slide that lip between inner rocker and cross member and weld it all together good and tight
