Drivers inner rocker measurements
Case
Hello,
A portion of my inner rocker panel has rusted off, I still have the tip/end with the large hole and 2 smaller slots, but need some measurements so i weld it back in the correct location. The drivers kick panel is gone so, no help there. I searched and was not able to find any dimensions, so what i need is a measurement from the center line of the large hole, back to where the drivers floor panel goes up to the section where the seat is mounted. I hope that makes sense. :) the floor cross brace is gone, so i cant use that as a measurement location. thanks in advance.
74 Bronco Billy
Case,
if you can post a picture and a drawing of what you want, I will measure mine this afternoon for you!
Forrest
