I’ve misplaced some of my notes. I need a measurement from the trailing edge of the driver’s side kick panel to the forward edge of the rear doorpost & doorpost support (this is the flange that will be wrapped by the door seals).
I searched; there are some measurements posted in this Tech Forum, but also statements that those measurements are (or may be) inaccurate.
Steve83 has posted a drawing showing “Door Opening Width” of 35.30 (https://www.supermotors.net/registry/media/1050287_1). This seems accurate or at least close (within bronco tolerances) on the passenger side but I’m not 100% convinced that’s the door seal flanges and not the doorpost bodies.
I’d like to know A-B, C-D, A-D and if the trailing edge of the kick panel is 90° (vertical).
Thank you,
Scott
Thank you,
Scott
