Duff Long Arms
jlake4130
phoenix, az
Well i pulled the trigger yesterday and ordered the duff long radius arms. I should have spent the money to have the trans rebuilt (4r70w) with the new ouput shaft from the AA kit i got. i think the look of the new arms will keep me motivated on my project better. Any tips, tricks on how to install them. Thanks!
bowhunter
You are going to love them. Just measure, measure and measure again before you mount the bracket. Everything else is pretty much straight forward. Good luck
77bronco_ed
Fairly easy install... Just need to get the brackets welded up in the right place.
jlake4130
jlake4130
phoenix, az
I have no problem welding the brackets but has anyone just bolted them on only? can you even do it that way? i'm guessing bolting it up first then when everythings perfect i'll burn em' on. I'll post pics on my gallery page as i get them and my progress installing them!
BIGED
Guru ????
Yep thats the way I did it
jlake4130
jlake4130
phoenix, az
the ups truck showed up today with the duff arms, YEAH! Here's a couple pics before the install.
JohnJohn
Richmond
I measured my stock D44 location from several points and put tape with marks on it where I took the measurements form they wrote them down.
Measure from center of the rear wheel to the center of the front wheel as well.
I tack welded the frame brackets in place then bolted everything on. I then measured several times to make sure the D44 was in the same spot then just welded the bracket on vs. drilling any holes.
My truck drove a bit better but I also found out I need to buy new headers because they will hit on the driver’s side.
I have a 3.5" lift and removed my 7 degree C bushings and went with 4 degree ones. I dont know my final castor reading yet but it looks like I have quite a bit now.
Dont forget to check if the front drive shaft is binding.
Good luck.
stlo
tulsa
i just got through installing mine as well....its pretty simple to install....just take your time and dont get in a hurry....im a welder by trade and i still drilled mine out and installed the bolts...even in there instructions they say to tack them after you get done bolting them...i weld on high pressure Gas lines and the thing is about just welding down each side is that if you get a crack or your just not that good at welding that crack will not stop till it reaches the end of the weld....yeah it was a complete pain in the ass to drill the six holes but my kids will be in it from time to time....IMO use the bolts and tack weld them as well....
sprdv1
REBEL
Tip # 5, don't leave them sitting in the barn for a year +, get them puppies installed, you'll love it..
"know someone got em still sitting in their barn" for a PROJECT ;D
trailpsycho
do these long arms make a better ride as well?
Yes, they do. This gets debated every once in a while here, but after a before and after for many people its difficult to say this one thing made the difference...I bet someone has done it piece by piece to see where they get the most bang for the buck, but most people tend to add the long arms while installing new springs and shocks...I have never heard of anyone being "disappointed." Most are extremely pleased.
Long arms add more leverage against the springs, so they (the springs) flex better, ride softer. This also helps smoothe the ride. With "soft springs", the long arm can really make for a pillowy soft ride that can be unnerving (slinky-like) without the right shocks. Either way you will notice more "body roll" unless you compensate with an appropriately valved shock. A well balanced setup will ride and handle extremely well...at all speeds
stlo
tulsa
trailpsycho is rite i guess i should have mentioned i run duff coils and their stage 2 shock hoops and their 70/30 shocks.....ride is great...but i always ran one shock per corner before the arms but noticed after the install of the arms i tried 2 per corner and it helped with body roll on the street....i mean hell my front shocks have 15" of travel...they are almost 36"s fully extended...for only 45$ per shock i dont see why you would pay 75$ and up for all the other shock...JMO
jlake4130
jlake4130
phoenix, az
Def drilling and bolting the brackets on first. Then when everythings perfect i will burn them in. Has anyone found a matching blue paint (like rattle can) to touch up the brackets after welding? Also, the bolts that go through the hiem on the end are HUGE!
stlo
tulsa
i have a pic of mine but i cant put a dam pic on here....lol.....i just painted mine black from the bottom of the frame up and left them blue from the bottom of the frame down...does that make sense?...lol...IDK if your supposed to say if you email me i can send you pic of mine....IDK are you suppose to do that on here?...lol
beaux312
Hartford, AL
man I love mine, measure, measure and measure. smoothed the ride right out. I wouldnt take anything for mine. I never used the bolts i just burnt them in and painted them with the frame.
jlake4130
jlake4130
phoenix, az
Got a liitle done. After drilling out the holes for the mounting brackets i decided that if for some reason something wasn't lining up something else was going to have to change because i wouldn't want the frame to look like swiss cheese! So i decided to burn the mounting brackets on too. And don't worry i measured like 10 times, lol!
