Duff Trac Bar Riser On HP D44
Okie69
Does this look like I’ve removed too much of the strength for this piece to still do its job? You can see what I had to cut to make it work on the HP D44. I’m thinking of getting it welded up and then trying to add a triangular gusset to add some strength back in. What do you guys think?
Okie69
Okie69
I would run it, and I tend to be hard on stuff. I can swing by and put eyes on it if you’d like.
Hey you can swing by and see how I’m doing anytime! I can use all the guidance I can get.
I didn’t realize you were close enough to just “swing by” shoot me a pm if you want.
savage
Bronco Nut
Renton
Hey okie69, I'm just curious why the spacer between the c-cap and raduis arm head unit . Is the axle and wedges wider than a stock Dana 44.
Okie69
Okie69
I’m not positive. There was an option for mounting on a HP44 on the duffs site and it included these spacers. I will say it felt like it was about as tight as it was gonna get with the spacers in.
I’m sure somebody that knows more than me will chime in.
savage
Bronco Nut
Renton
I went on Duff site and see they use them for the larger diameter axle tubes.
Okie69
Okie69
This HP D44 looks to have 3 inch tubes. My stock D30 has 2.5 inch tubes. That probably doesn’t help but I was wondering.
Yeller
Rogers County Oklahoma
I’m not too far away….. I don’t think LOL. I’ll send you a DM
Madgyver
Bronco Madman
here is what we did.... 77 FWHP Dana44
reused existing adjustable tracbar
Qumanchew
Kutztown PA
You guys have me wondering about those spacers. My hp44 has 2.75" tubes and my c bushings are squished out pretty hard. I thought I compensated for that when I welded the wedges on but now I'm second guessing myself. That was years ago though and I can't remember what happened last week!
Okie69
Okie69
Found someone in town to weld it. Hopefully it’s burned in enough 😬
Okie69
Okie69
HAZ looks good, front side weld ehh looks well ok. it’ll hold good nuff. Oh Skiddy….lol
I’ll probably still holler at you when I get ready to assemble the rest of the axle. I’m still a bit intimidated.
