Duff's Booster - Quick Help Needed
Mr Joe
I'm installing the booster today. The instructions mention a backing plate going between the bracket and the firewall. I didn't see one in the box. Is this necessary? Does it come in the kit??
bronco std
Berryville, Virginia
All mine came with is the triangular shaped bracket that the booster attaches to. The bracket is attached to the firewall in the 6 bolt locations if I remember correctly. Hopefully this pic may help.
bronco std
bracket, This is the only I picture I had with me at work that shows that bracket
Blue71
Don't think I had a backing plate either. I just mounted it to the 6 bolts in the firewall that were already there. Be sure to get the adjustment on the rod that fits into your booster adjusted correctly. If your rod is adjustable like mine. You may have to adjust it a few times to get it the way you want it. You'll love the Power Brakes. I am running Power drums and it stops 100% better. Keep us posted.
Good Luck,
Blue71
Mr Joe
Mr Joe
I found the backing plate. It has 2 holes and is mounted to the passenger side. I'll get pics when I'm done....
Mr Joe
Mr Joe
Here's the backing plate, it's mounted on the left 2 bolts...
Blue71
Looks great. So whats the verdict? Does she stop better? Are you running drum or disc?
Blue71
Mr Joe
Mr Joe
Well, It hasn't left the yard yet. I can tell by moving it in the driveway that it's much better.
