Early Bronco AOD transmission pan modification Driveshaft clearance
pcf_mark
Solid solution. Are you using a stock diameter front shaft or the later Explorer skinny?
partsloco
partsloco
Stock drive shaft. I wasn't aware of a explorer conversion. How is the clearance with the explorer drive shaft.
englewoodcowboy
Lick Creek Restorations
With the AOD swap you need to get new driveshafts to have the correct lengths for the driveline change, when you get them, just order a smaller diameter front shaft and the problem is solved and not over complicated.
Sent from my iPad using Tapatalk
Viperwolf1
electron whisperer
X2. And if you pickup a 1st gen explorer front shaft it's already the smaller diameter and correct u-joints and will only need to be shortened/balanced.
EricLar80
I have a 4R70W with the explorer smaller diameter driveshaft. It mostly misses the pan, but seems to rub it ever so slightly under some conditions. Not enough that I have worried about it - seems to have just taken the paint off.
Eric
