This is a stock bronco frame full caged and fabbed by west coast broncos i have had awhile but time and other projects have not allowed me to finish it it has 351w roller engine with edelbrock intake hei distributor all new gaskets and paint nice valve covers the c6 auto 4x4 trans with np205 t case rockrawler 4x4x2 style steering box ported for hydro ram assist full width dana 44 HP with new 1 1/2 dom tubbing and heim steering drop pitman quick disconnnect steering 7 inch wild horses front springs lower trac bar bracket and drop pitman pushed out coil buckets with tubular shock hoops thw rear has wild horses 5.5 leaf springs with a 14 bolt full floater rearend already setup for early bronco 4 wheel disc brakes setup all the way around needs calipers and brake pads hoses before complete but all hardware is there and installed brake pedal setup for stock ford master or you can install hydro boost no gas pedal as of yet pr fuel lines needs radiator and front engine dress up and carb alot of hard work been done to this just needs a bit more help... 5625771289 for more info!!!
