PGreenlawMD
Original bronco solenoid. Power coming in on left hand side with multiple attachments to the large post. Small "S" post with green wire with red stripe connected. Small "I" post with brown wire connected. Right large post with cable running to starter.
Powered post has 12 V at all times. Starter post by definition should only have power when cranking the engine.
When should the ''S" post and "I" post read power. I don't have anyone at home right now to crank the engine while I check. Should either the "S" or "I" post have power with the key in the run position but not cranking the engine? The reason I ask is that I have no power on any of the small posts of the solenoid with the key switched to run. Trying to wire in a relay for the sniper pink wire to switch on the ECU.
The positive side of the coil does have constant power with the key in the run position. The engine does turn over and start fine since I have wired in a separate switch for the sniper pink wire directly to the battery.
Just trying to understand this 1967 wiring setup.
