Early Bronco Tailgate Seal exhaust problem fix or solution
Jaxgtc
Problem solved in much the same way that the original full cabs were built. Pretty much what you did is available as replacement parts; the tailgate bed seal, tailgate metal strips, and all of the various pieces of rubber weatherstrip to go with them to seal the tailgate and liftgate area. If you are having that much fumes from the exhaust, you might want to look at your exhaust system.
Good luck with it.
bronconut73
The original system of seals back there work quite well.
When my lift gate is slightly ajar the exhaust really gets pulled in hard. But when closed up the factory seal system works pretty good.
The exhaust being turned out to the sides behind the back tires usually helps tremendously.
