DonsBolt
Yo guys
I have to replace the little round bushing on the rear of my radius arms. I hope I don't have to disconect everything to replace them.
Here is what I hope I can do.
Jack the truck up, either on a lift, or with 4 big jack stands.
remove front tires
Remove front spriings
remove track bar
remove shocks
remove the front of the driveshaft.
Then loosen the two bolts on the rear of the radius arms, then remove one of them, pull the axle foward just enough to change that one out. The put the bolt back in that one loos, remove the other one, and do the same.
I hope there is enough movement in the drag link, my braided stainess brake line, so I don't have to mess with the steering or the brakes. I am sure there is plenty on the right side, the left is what I am concerned about.
Just figured I would see how you all have replaced those donut shaped bushings, and any tricks to make it as easy as posible.
Also I have a set of the rubber bushings, would you use those or order a set of urethane bushings or even a set of the offset bushings??????
remove front tires
remove track bar
remove shocks
