I purchased that same kit about two years ago and it is excellent in quality. I only had one very slight issue, but I really don't remember what it was. If I remember correctly it had to do with the pads. It is rather hard to explain but there needed to be a very small piece that I had to grind down because it was rubbing on the rotor. It was on the metal mounting tabs and not the pad it self. I don't know if all the pads are like that or just the brand that was shipped to me. It only took a few minutes. The e-brake works fine also, I ended up purchasing the cables from WHorses, which are a little long, but they work fine also. They were very easy to adjust also. I went on line and found a good source on how to adjust them and there isn't much to it. Over all I would use this kit again, very simple straight forward install. I also use Tom's Bronco gas shocks, which are a smaller diameter than most and fit with out having to modify the shock mounts.
