Edelbrock #1406 Carb Tuning WB Verify
RonJones
I decided to join the wideband revolution and verify my 302's carb tuning with a PE bluetooth kit. About 20 yrs ago I put an offroad kit in the carb and played around with the jets and rods, doing it old school (stopwatch and that seems good/bad). I'm at 1,000 ft altitude. As I recall, this jet/rod combo is richer than stock, but not as rich as my first try, which absolutely cratered my already dismal mpg. I don't remember which jets I have in it but the initial run is with yellow 4” Hg springs and #1456 rods. My goal was AFR's of idle: 14.2, WOT: 12, Cruise: 15. I ended up going to a 8” spring as I had a lean spike when vacuum went below 10 in Hg. Runs pretty well now!
https://rumble.com/vo1oit-edelbrock-carb-calibration-check.html
https://rumble.com/vo1oz7-edelbrock-carb-vacuum-springs-calibration-check.html
blubuckaroo
Grease Monkey
Ridgefield WA
You're lean. The springs won't make it richer. They just they just allow it to become richer at a different load. Use the metering rod/jet matrix to fix your lean condition first.
R
RonJones
You're lean
I'm sorry, when? Idle, Cruise, WOT?
I have the numbers I was looking for. The table I was using is seen below, followed by a second table from another source:
Seventee
In the sticks of MT
R
RonJones
That's exacly what I was thinking when I bought it! If I had a criticism of the unit, I wish it displayed an optional 5 second average, as the direct readings can be kind of bouncy. The trend line sort of does that below, but gives a graphical sense rather than a number.
