I decided to join the wideband revolution and verify my 302's carb tuning with a PE bluetooth kit. About 20 yrs ago I put an offroad kit in the carb and played around with the jets and rods, doing it old school (stopwatch and that seems good/bad). I'm at 1,000 ft altitude. As I recall, this jet/rod combo is richer than stock, but not as rich as my first try, which absolutely cratered my already dismal mpg. I don't remember which jets I have in it but the initial run is with yellow 4” Hg springs and #1456 rods. My goal was AFR's of idle: 14.2, WOT: 12, Cruise: 15. I ended up going to a 8” spring as I had a lean spike when vacuum went below 10 in Hg. Runs pretty well now!
https://rumble.com/vo1oit-edelbrock-carb-calibration-check.html
https://rumble.com/vo1oz7-edelbrock-carb-vacuum-springs-calibration-check.html
