Looking for some info/websites/forums/threads for a friend who is swapping a 1990 efi 460 into his 79 F150. specifically looking for parts lists, how-to's, pictures and write ups.
the 79 had a 351M/435. the 90 donor truck is a 2wd auto. he is a carb guy so little knowledge of EFI systems. I've done an EFI swap and modified my own harness but I don't want to spend 50 hours on the phone explaining where the pink wire goes. he is 200 miles away so I would like to point him to some good resources.
I assume the F150 would be the same as a FS Bronco as far as the 460 swap is concerned or even the 460efi-to-stock wire harness mods.
here is the stuff that needs to be done
-motor mounts
-flywheel/pressure plate/clutch
-exhaust
-high pressure fuel system
-air intake plumbing & filter
-efi harness wiring graft
thanks!
-motor mounts
-exhaust
thanks!
