- Sep 16, 2014
- 21
Looking for some advice (aren't we all).
We just purchased a 74 project with no engine/trans/transfer case. We are leaning toward doing an Explorer swap but a swap from a 5.0 F150 would also be a consideration. The engine build would likely include AFR165 heads, a torque cam (something like a CC XE264), and the stock EFI intake from the donor. A 347 stroker may be part of the equation depending on the condition of the short block. Definitely hope to use the auto transmission (4R70w?) from the donor. We're not going too large on the tires (31-33) since it will mainly see street cruising. Dana44 in front and 9” in the rear. Will likely upgrade to larger spline axles in both. Would like to put some sort of trac-loc in the rear.
I'm assuming an AWD/4x4 donor is preferred, but does it have to be an AWD/4x4 or will 2WD work using some type of adapters?
If 2WD is an option, what adapters would be needed?
Which transfer case is typically used with these swaps? Prefer a manual case and not opposed to upgrading to an Atlas.
Since EFI Guy seems to be MIA, are there other options for the harness mods/computer updates?
Any other recommendations given the engine configuration we're considering?
I did some cursory searches but didn't find all the answers given the configuration we're considering.
