I'm toying with the idea of converting my BC Broncos early 24 gal tank to the Holley Atomic 2 EFI when it comes available. I'd also like to keep my Aux Tank functional without running fuel and return lines everywhere and switching to a 6 port electric fuel valve. The 6-port EFV's I've seen are rated to 60 psi (maybe), but plumbing schematics show them placed to switch before an inline pump.
Holley sells a inline regulator/filter to mount close to the main tank, so only a short return line is used.
I'm thinking place a low-pressure inline electric fuel pump on the Aux tank outlet and Tee it into the Holley inline regulator/filter return line (see below). The fuel pump would be powered by the Main/Aux selector switch. When the Aux Tank fuel level nears zero, switch back to the Main Tank, which should now be several gallons fuller. This way a short return line is used and no 6-port EFV is needed. If the Aux fuel pump doesn't have a check valve, one can be added.
Any thoughts?
Any thoughts?
