EFI Code 96
jamesonfd
Newbie
Would appreciate any ideas.....RJM harness, would like to start this thing.....Self test shows a 23 (I can replace the TPS) and a 96 (Relay did not send current to the fuel pump).
The pump runs when power is applied to it. If the ignition's on and I ground the Fuel Pump pin on the Self Test connector I can hear the relay (key on), but the pump doesn't run. No relay or pump run when I cycle the key on without the STI shorted.
Any ideas? Frankly, I'm not a "build your own harness" guy.
