What all needs to be done with the EGR on my 87 5.0 HO intake on my 289. Will simply unplugging the Egr work or do I need to do something else. I remember something about a diode. Will not doing this cause limp mode.
I would remove the entire egr plate (In 87 it should be sandwiched between the Throttle body and the intake) and then use a resistors to send the right egr position signal back to the ecm. Without the delete resistors it will think it is open when the correct signal it should be getting is instead closed.
Yep. There is a diagram here. (About 2/3 of the way down the page) http://fordfuelinjection.com/harness.html
I picked up my resistors at radio shack. I doubt you'll find the exact resistance without adding them together in series though. I.E. A 250 plus a 120 in series is 370. (Don't add them in parallel since that would actually reduce resistance) Watch out for the K though as it represents X 1000 ohms. (If you know all this already then great but I added it anyway even if you do in case others read it as well that don't)
You can leave the plate on but I would at least disconnect the coolant lines. They will add heat to the intake that isn't needed. (The cooler the air is coming in the more dense it will be) You'll also want to pull the egr valve itself off and put a plate over the opening. Otherwise you can end up with a vacuum leak there. (You might be able to just cap the end of it as well)
I knew I saw it on there but I couldnt remember where. I didn't run the coolant lines in the first place because of the heat issue.
Thanks for your help
