stock74
- Mar 14, 2004
- 242
My Bronco has been starting and running well and maintaining good fuel pressure. However, the other day when I went to move the Bronco from the driveway into the garage it would not start. I have an fuel pressure gauge mounted in the cab (has an electric sending unit). I noticed there was no fuel pressure and around the same time noticed the fuel pump was not making any noise when I turned the key to the run position.
At this point I checked the fuses and relays which checked out just fine. Then I verified the connections at the pump are good and 12 volts is momentarily being supplied when I put the key in the run position. The pump is external and mounted on the frame rail so I decided to hit the side of the pump a few times with my hand. After hitting the pump it started working again and the engine and fuel pump ran fine.
Is this a sign of the fuel pump going bad?
Thanks for your help!
