casadejohnson
Bronco Alchemist
- Jan 21, 2005
- 3,587
Going to work today my Bronco had a quick stutter and then I got a puff of smoke from the glove box ( Where my ECM and relays are located ). I shut it down and checked the relay. It was pretty warm so I swapped it out and started it up and it ran fine. Next I swapped back to the original relay and it still ran fine with no more smoke or electrical burning aroma. Fast forward to the end of the day and I drive home without issue. When I pulled it into the garage, I see that I have a fuel leak. Further inspection reveals that the insulator on the positive fuel pump connection is melted and is the location of the leak. So my theory is that a power surge from the smoked relay to the insulator caused the melting and leak. What I don't know is if the problem is just a bad relay or is there another problem that fried the relay which in turn fried the pump? I want to go wheeling this weekend but I'm a little scared of it now. I don't want to put my kids in the back if its just a fire waiting to happen. Anyone Seen this before? The ground is good and the fuel pump is not very old.
