omureebe
- Jun 18, 2013
- 403
I used a stock size plastic replacement tank. I cut a hole in the top and added a Holley Sniper drop in fuel pump with return lines. Only thing I messed up is put it in the front half of the tank and can uncover the pump under very hard acceleration.
I used the Hyperfuel retrofit pump - has AN fittings for supply return and vent. It sits 3/4” on top of the stock tank so that 1” body lift is a must, and after a few hundred miles no problems.
https://www.summitracing.com/parts/hpf-40015/overview/
