luderchris
Does it spit, sputter, cough, like it's lighting off fuel or does it just crank?
Verifying spark should be step one. The "too hot to touch" ignition coil is a huge red flag.
Just cranks. Not trying to start at all.
Pull a wire at plug and see if it arcs to something metal while cranking. I shouldn't have to tell you not to hold it! Report back and we can go from there.Not yet. Wife pulled me out if garage. I am going to check spark/ignition tomorrow. Any tips on what to check? I will be out there again in the morning.
a stock '97 f250 would have a roller cam in it and the dizzy would be set up for an external tfi module. If you're running an a9x eec, you either rewired in the external tfi module or swapped the dizzy to an earlier version integrated tfi dizzy. Which one?
1. If you did swap the dizzy, did you also swap the gear off the bottom? If not, and you may want to check this anyway, is the rotor still rotating as you crank the engine?
2. If not, and you wired in the remote tfi, i think there's a wiring issue there, which would also account for the hot coil.
3. Maybe some combination of the two.
Hth, joe
Fuel, ignition , and oxygen; good deal! Congrats on overcoming your first efi crisis. It won't be your last. ;-)
Everything I touch is jinxed. Congrats, you've been infected.
Let's start with you posting a picture of your EEC code.
