Sbolt19
I was driving home for lunch on Friday and my EB started acting up. There were no warning signals, nor did it act like something was wrong. I was going up a hill and it was like someone reached over & turned the ignition off. I got it pulled over and it started right up without a problem, and it did it again. Actually it cut out 4 times in a 2 mile trip.
The system that I am running is off of an 87 Mercury Grand Marquis, speed density unit. I have checked the fuel pressure on the rails to see if it was the fuel pump not getting pressure, but I am running between 34-36 with just the key on, not the engine on. I thought that the pressure was supposed to be between 24-28?? I have checked all electrical connections, coil connections, batt. etc. and everything is tight & secure. I am, by no means, an EFI guru, but I can't figure this one out. What would cause it to cut out just all of a sudden?
