EFI problems
roundhouse
I have a '90 EFI 5.0 in the EB for 10 years now,, not had many problems.
Now it will crank and run for about 3 seconds and dies, gauge says I have 40 psi at the rail.
Any ideas.??
Bronco_69
Monette Ar
check for spark after it dies. i had the same deal and it was the sensor inside the distributor. swapped it out and good to go!!
barronj
PM greenbullitt, he might be able to help.
Great Alan Keyes quote. Not enough Alan Keyes supporters out there.
ransil
Swap in a new distributor, to eliminate the TFI & pick up hall sensor.
any codes??
R
roundhouse
Its really bad gas, or a problem in the tank.
runs fine when I put the pickup line for the EFI pump in the can of gas for the lawn mower.
