EFI replacement (options/opinions?)
lars
Been here awhile
NorCal flatlands
As I think others have noted part of the problem with injecting a 351W is simply finding an intake. Manufacturers seem to be losing interest in making compatible manifolds. I got my hands on a Trick Flow R combo before TFS stopped making them. The Lightning lower is insanely expensive when you can find one. Edelbrock used to make an upper/lower combo that outflowed the Trick Flow setup I have, but they stopped making those years ago. Edelbrock does still occasionally produce their Super Victor EFI manifold, which was my backup plan (and maybe I should've gone with it anyway): https://www.edelbrock.com/super-victor-efi-351w-intake-manifold-29245.html Out of stock at the moment but they do seem to be producing it still. With one of their 90 degree elbows and a throttle body of your choice, you are in business though I imagine hood clearance is still an issue. And you'll still need fuel rails, blah blah. Any EFI system that is designed for port injection will work.
walker_creek
walker_creek
Had to put this off for a while. (Hate it when work gets in the way of Bronco'ing). But here's an update:
Ordered the Pro-Flow 4 this morning. Spent a half hour on the phone with Edelbrock Tech Support yesterday and have decided to go this route.
I was really considering trying to piece together an Explorer setup, but decided I didn't have the spare hours to do that.
Here were the things that made the decision for me:
1. I figured I would eventually upgrade to controlled timing anyway, and the Pro-Flow included the distributor, etc.
2. While I currently have a good intake, I don't truly know how compatible it is with injection. I know the ProFlow system will all be engineered to work together.
3. Admittedly, I am just too spooked about the Sniper 1 failure to try the Sniper 2.
4. After reading the ProFlow install manual, most of my wiring is in place from the Sniper...I don't think re-wiring is going to be that much of a chore.
5. My current intake only had one coolant port and it was used up by the Sniper sensor. I had to disconnect my dash gauge and rely on the Sniper display for coolant temp. That was very hard to read in the sun. The Edelbrock will give me enough ports to reconnect the Bronco coolant gauge. I can also get rid of the display stuck on the dash.
6. The ECU is not in the throttle body.
7. The Edelbrock manual recommends a 180F thermostat. I originally had a 180 when carbureted, but had to put a 195 in to keep the Sniper in "learn" mode. Since then I've had heat issues when crawling. I'm hoping the 180F thermostat will help with that (although I know I still have some fan shroud issues that need correcting)
8. I'm assuming the direct injection has to be somewhat better that throttle body.
I hope to start swapping this over in a couple weeks. I'll keep y'all posted...and thanks everyone for their input.
Ether
Tulsa
Love my Pro Flo 4!
Makes total sense why it’s “better” for small block Fords with the Dizzy up front near the Holly ECU (contained in the TB unit).
JeepGuy
I'll be waiting intently for the outcome of this. Take pics of the install if you can give us a heads up on any issues. My next big purchase is gear and lockers followed closely by an EFI set up. The Pro-Flow 4 has been at the top of my list as well for several of the same things you've listed above. I had planned on upgrading from the stock intake and adding electronic ignition/distributor so having that built into the upfront cost of the Pro-Flow is nice.
Good luck.
.94 OR
Willamette Valley, OR
Any updates?
walker_creek
walker_creek
I'm hoping to get back to this this weekend. I got sidetracked by a barely running '78 Bronco at an estate auction I thought I needed!
walker_creek
walker_creek
I FINALLY have an update on this. Took the long Independence Day Weekend to focus on the Pro-Flow install after not touching it for months.
I finished up all of the wiring. I was able to re-use about half of the wiring I added for the Sniper. It looks to me like the O2 sensors are probably interchangeable.
Setting the timing was super easy. When I first turned the key I didn't really expect it to run, but it IMMEDIATELY ran smooth at default (I think 725) idle. The Edelbrock Wizard (bluetooth app on the phone) walked through all the initial setup.
Set the timing, adjust fuel pressure regulator, minor adjustment on the idle screw. That's about all the "old school" tuning that was needed.
I was driving it down the road within an hour of the first key turn.
Engine runs SOOO much smoother than it ever did with the Sniper. Throttle response is so much better. And it should only get better with more learning.
It's only been a day, but so far I'm very impressed with this system.
Johnnyb
Flagstaff
I had an experience with what I thought were "interchangeable" sensors that you might want to be on the lookout for. When I put in my pro flo 4, at the same time as I installed Dakota digital, the water temperature sensors were identical in appearance. Yet on first startup the water temperature on Dakota was reading low in the water temperature in Edelbrock was reading high by about a 40° difference. I swapped them and they both read correctly to a reference IR gauge.
Other than that my experience was nearly identical to yours, the engine fired up and ran well as soon as I turn the key. I never actually had that experience before, success on the first attempt. That's why I'm so pleased with the proflo 4. Great work and I hope you enjoy it.
-JB
jamesroney
Fremont, CA
It is official: @walker_creek is now my newest, most favorite Bronco owner of the day.
1. Not only has he seen the light, he is actually POSTING about how he was duped into believing that the Holley Sniper, (or any aftermarket throttle body fuel management system not named GM TBI) is absolute JUNK. The vast majority of Sniper users drink the Kool-aid and then go preach to all of their friends about how great it is. From a position of total ignorance. THEN when they get a decent EFI system, they go silent. I wish that everybody could read what was written above. "Engine runs better." "I am impressed." etc.
No warranty left. Electrical problems are fixed. I shut the alternator breaker off thinking it would be an anti-theft method. Turns out will start just fine. I didn't notice the voltage dropping until it was too late. That being said, I consider it a major weakness if low voltage kills the ECU.
2. Hallelujah. Your alternator failed, and Your Holley destroyed itself. That's not just a major weakness. Its a steaming pile of excrement. IDGAF what Holley says, or what anyone says. Anything that bolts to an automobile should be able to gracefully accommodate a power interruption. My $15 Roku Remote doesn't self destruct when the battery gets low. Holley is the absolute worst, and if the Sniper 1 was worth a shit, there wouldn't be a Sniper 2. MOREOVER, anyone that bought or owns a Sniper 1 should be able to receive a Sniper 2 at COST. Why is Holley allowed to profit TWICE from their incompetence? This drives me absolutely insane. And for those of you that are about to say something incendiary about the "warranty period" you can go pound sand. The warranty period is NOT the service life of the item. It isn't a tire, battery or consumable product. It's a sophisticated fuel management system that should be capable of reliable operation for an infinite service life. The components in the Ford EEC-4 SEFI are now 40 years old, and STILL running fine. (and replacement parts are available...) So your 1 year warranty is horse manure. Besides, on a Bronco restoration project, it might take a year just to get the thing out of the box, and installed.
3. PLEASE provide periodic updates to this thread as events happen. 40 years from now, your Pro-Flo should still be running perfectly. I hope to see a post dated 7/7/2066 that says "I ordered a new "****" from Edelbrock for my Pro Flo 4, and they had it in stock..."
Congratulations.
ntsqd
heratic car camper
Upper SoKA
If you think that the Holley is junk you really, really won't be happy with the EFI from one of the old names in mechanical fuel injection. Thankfully that system is long gone. But not before I had one inflicted on me..... Was a cool car though!
I'm not naming it because I'm no longer sure whose it was, but it made the lone Holley system that I've worked around look really good!
For a stupid simple system I like the GM TBI, but it is both of those, stupid and simple. Operate it within it's limits and don't expect very much from it other than it just works and you'll be fine. Want more than ~275 HP or make other demands on it and you're wasting your time. Nothing that I ever saw that Holley did with that design looked like anything that I'd want.
walker_creek
walker_creek
I'll update more once I get some more miles on. Still need to add a 2nd temperature sensor so the factory gauge works, and of course I found a minor fuel leak that needs a little attention. I'll post some pics once I figure out how to sign up for "contributor". Figuring out where to mount ECU, fuel regulator, etc, etc. seemed to be one of the biggest time consumers. I moved the ECU four times before even connecting a wire to it.
Bung72
Ripon, Wisconsin
Congratulations walker-creek! I went with the Edelbrock Pro Flo 4 two years ago for my 1972 302 Bronco. Got about 3000 miles on it so far and am VERY happy with it over a FiTech t/b I battled with for 4 years. I installed it during the winter downtime when I do repairs and upgrades. As you said the Setup Wizard does most of the work. I'm as cross-eyed, slack jawed stupid as they come and it was a breeze.
Bung72
Ripon, Wisconsin
I mounted the ECU to the underside of the cowling ahead of the windshield to protect it from the weather and heat of the engine compartment. Also, with a tilt front end I have no inner fenders, so the engine bay gets drenched when driving in a rainstorm.
Andrewdevi
Bung72
Would like to see pics of your location of the ECU
Bung72
Ripon, Wisconsin
Bung72
Hello, andrewdevi. Here are the pics you requested. The 3 stainless bolts on top of the cowling hold the ECU and fuel pump relay to the underside of the cowling. The bolt closest to the windshield holds the relay and the other two hold the ECU. The other pic shows where and how I exited the firewall with the wires. The pic of the ECU is the best I could do cuz of all the junk under my dash. Have a great day!
