Ran self test came back with tps setting
code 22, 41, 35, 53, 54, 57, 81, 82, 83, 85 ran out of time may be more
TPS circuit above maximum 4.5 volts. X TPS circuit has intermittently failed above maximum 4.5 volts.
checked volts and it is 4.98 to 5.01 closed to full open checked at the green wire and grounded the other on multimeater. Have replaced the tps and samething.
New motor, ryans harness, a9l computer manual trans
could I have a bad computer the motor runns but rich and after it warms up it will not start again till it cools down. When you do try to start it after it is warm it is rich and blows out the tail pipe. I need some help need to have it up and running by the 40th may 3
