- Aug 22, 2005
- 14,493
I am wanting to hook up a relay for the fuel pump. I have the parts but I am a bit unsure how to do this. My holley commander 950 has a wire that runs the pump. My new harness also has a wire that runs the pump. My holley instructions tell me to use a relay. Both wires will become hot when the key is on. The holley wire is small. the harness wire is bigger. If I use the holley wire for an exciter / signal wire is there a chance of backfeeding to much power into the ecu? Am I making this harder than it needs to be? It sounds kind of silly to interupt the harness wire but the pump needs to be controlled by the ecu. I should be able to hook it all up and use the harness wire for the power to run the pump ( hot with the key on) The relay should allow the ecu to signal the pump to run. Correct? Do I need an inline fuse on the signal wire? if so how big of fuse?
Bax
Bax
