- Oct 22, 2003
- 1,020
I know this question has been asked a lot, but I'm looking for som fresh perspective.
I have a '71 with a 351W and 4 core radiator. I have absolutely no cooling problems on the highway in hot weather but I tend to heat up too much on the trail at low speeds. And when the weather turns cold I have zero heat, regardless of what thermostat I run.
I picked up a Taurus fan this weekend for practically nothing and thought that I had the winter and trail problem beat. It turns out that I only have about 2 1/4" oc clearance between the radiator and the water pump, so the Taurus fan is about 2 times too thick to go in there.
I thought about trying to run two 12" fans across the diagonal of the radiator. The cfm ratings of both combined is barely enough. Does anyone think this will work?
I know a lot of you guys are running electric set-ups. What combinations and/or modifications did you use to make it all work? Any help would be appreciated.
