- Jul 31, 2001
- 8,802
Battling the heat issue with 105deg F temps, multiply that with low speed wheeling, well built 418 stroker and efficient heat removal is a priority... hence "The Torture Test"... at least here in the PNW...
I've spent literally dozens of hours studying and talking to Ron at Ron Davis radiators, Griffin tech dept, and reading excellent articles like BellaVista put together on Pirate....
With that, here's my simple test that I am working on to cure my heating issues. I learned a LOT from these experts that research these issues and solve them on a daily basis...
I run a brass/copper old school radiator that the core measures at 24.5"x18". With an Exploder front dress I run the Exploder clutch fan with a hand made fan shroud that the fan clears by 3/4" around it's circumference and protrudes into the shroud exactly 1/2 the depth of the blade.
I ran a simple back to back test comparing the Tauras fan with it's stock shroud and an Exploder clutch fan on this radiator. Both shrouds were fitted to the radiator. The Tauras fan shroud comes within 1/2" inch vertically (top and bottome) of covering the core and horizontally I have 3/4" of exposed core on each side. Ron said that ANY shroud must cover every row but it can only cover up to 70+% of the entire radiator (horizontally on a cross flow) and still be extremely efficient.
My custom Exploder shroud covers the entire radiator- both are sealed to the radiator.
So, I drove 20 miles up hill with the last 7 miles at 10-15 mph on a 10% grade in 105 deg F temperature. The first 15 miles of driving just got me to the grade and up to temp.
Results:
The Tauras fan allowed my temp to climb to 212deg F. and this was when I turned around yesterday at the base of the 7 mile climb...never finished the test yesterday since it was continuing to climb...
The Exploder fan allowed my temp to climb to 196 degrees and this was at the bottom of the steeper part of the grade (where I stopped yesterday) and stayed at that temp for the entire 7 mile steep climb at 10-15mph. I ended up picking up 6 teenagers 2/3 of the way up and they all climbed in the back(this was a stop on their West Coast skateboard/longboard tour-professional filming was happening...anyway) and my temp rose appr 2 more degrees with the extra weight. Every corner or every time I had to slow down to turn on one of the switchbacks, my temp would drop 2 or more degrees (just in the 15 seconds that I would let off the gas and turn).
Both fans allowed my Bronco to sit and idle for a long time without any temp increase at all. Put a load on the stroker and it's a different story.
For me, this shows that the Exploder fan draws more air than the Tauras fan does. I have two Mark VIII fans sitting on the shop floor but I have to modify the core support to try them for the test. Maybe some other day...
Here's the kicker. My old school radiator only drops the temp of the water coming in from the engine a WHOPPING 22-24 degrees! Everything I have read says the radiator should cool better and have a larger temperature drop from inlet to outlet.This was measured by an infared gun. Yup, that seems to be my biggest problem right there. Guess I'll try an aluminum radiator after the SEFI conversion is completed and move "stuff" out of the way so I can get even more surface area.
I'm looking at upgrading to an aluminum radiator since once they are constructed, they cool more efficiently than brass/copper radiators do.
I'm actually looking at a Raptor/F-150 (2013) radiator since they are sooooo wide and are relatively short height. 38"x15.5" perfect fit for my rig with a LOT more cooling surface area-almost 40% or more over stock.
Even though I ran the TC unlocked the entire way, my 4r70W tranny only got up to 150deg F since I have two coolers in line. One has it's own fan on it and of course it's mounted outside of the engine compartment (hot air trying to cool something isn't very efficient) and the other is a Super Duty tranny cooler which is mounted over the recommended distance from the radiator according to Ron Davis and Griffin...so long as you have over an inch btw them, air flow through the radiator is not an issue.
Guess I"ll stick with the mechanical fan and not have to worry about relays, wires melting, fan motors dying, etc... just a bit less to go wrong...
Hope this helps somebody.... have fun, go wheeling!
Results:
