Electric pusher fan wiring, key on & off
JWMcCrary
Currently in a wiring makeover and I'm wanting to have my pusher fan kick on when the temp reaches the setting but also when I stop I would like to be able to run the fan without having the key on (which is what I've been doing for years). I know this can be done with properly placed diodes using a constant 12V source and a keyed source. Do I need a diode in both 12V sources? And, what diode do I buy? part number, link, etc.
Any direction very appreciated.
garberz
Bronco Influencer
Conejo Valley, Ca.
My fan for my trans cooler is wired up through a three position switch.
Off
On
Auto
It runs without the key needing to be on. The auto mode uses a thermostat to turn on when the temp is reached. This is all controlled by a relay, and the relay is switched by completing the ground circuit. Simple set up. No diodes.
Mark
SP73
Off
On
Auto
Mark
This is the way to do it!
JWMcCrary
JWMcCrary
Yes, I agree, that is the simplest, cleanest way. I have a single throw switch that is factory labeled that I want to use. I figured it out using an extra relay and not having to buy anything else.
