To give more background. Before I took the dash apart and disassembled the truck for the body shop all the lights, turn signals and flashers were working as expected. The truck sat for a couple months at the auto shop before they even started on some body repair and paint. I know that they hotwired the truck a few times to move it around and when I picked it up I noticed they left a jumper wire between the battery and the ignition coil. So they fried the ignition coil and the truck wouldn't even start any more. I replaced the ignition coil and then realized battery wasn't holding a charge so had battery tested it failed and had to replace it. Then it seemed like my voltage was running low and alternator wasn't charging as it should so had it tested and it failed and just recently replaced it. So I'm not quite sure what the body shop guys did but seems like I've had to replace quite a few components after I got it back. The fuse panel was all rusted out so I replaced it with the centech one. I'm confident the fuse box is connected properly.
I was initially having problems getting headlights, instrument lights, markers, turn signals or anything to work when IGN was "On" but through some of the ground recommendations from you guys I've fixed the initial issues. I now have all the headlights, brake lights, markers and instrument cluster lights lighting up however my problem now is with the turn signals and flashers. These are my current symptoms.
Ignition "Off"
Battery Voltage: 12.0V
Headlight Switch On: Headlights, tail lights, markers and turn signals all on
Flashers Switch On: I only get 2 solid turn lights in cluster no flashing. No front or rear lights flashing
Turn Signal Switch On: nothing (expected)
Flashers & Turn Signal Switches On same time: the 2 solid turn lights in cluster turn off. No front or rear lights flashing.
Ignition in "On" position
Battery Voltage: 11.88V
Voltage at Ignition Switch (Stud on back to ground): 11.68V
Flashers Switch On: I only get the 2 solid turn lights in cluster no flashing
Turn Signal Switch On: I get 1 solid turn light in cluster but no flashing. No front or rear lights flashing.
Flashers & Turn Signal Switches On same time: the 2 solid turn lights in cluster get brighter.
Since the battery voltage was right at 12V I connected jumper cables to another car to see how things performed. The emergency flashers started working.
Jumper cables to another car
Battery Voltage: 13.50V
Voltage at Ignition Switch (Stud on back to ground): 13.22V
Flashers Switch On: Works! Flashes in instrument and the front and rear turn signals flash.
BTW, should the front turn signal lights be On when the headlight switch is on? Any other thoughts on where to start?
I have a mechanic buddy coming over tomorrow to get a new set of eyes on things but these seem like some strange symptoms so any thoughts on where to start next would be appreciated.
