FrankSG
Hi everyone,
I'm in desperate need of some electrical help with diagnosing my Bronco. This has been an ongoing issue. I think that I solved it and it keeps coming back to haunt me.
The issues is that when driving, it appears to be draining the battery...enough so that if I turn it off, the battery has no juice to start it. Additionally when I am driving it, and I put a turn signal on the motor pulses as though it want to stall with every blink of the signal.
I replaced the alternator, think that it wasen't charging the battery. After replacing the battery and alternator, I thought that the problem was finally solved. I tested the battery voltage without it ruining and got between 12 and 14. running under full load (lights, wipers, etc...on), and was getting around 13-14V. When I arrived at worked today, I barely made it in the parking lot before it died. (it wasen't a good first experience bringing it to work and having to push it into a parking space).:-[ I tried to crank it over and all I got was a few weak turns out of the starter before it completely died. The interesting part is that the headlights appeared to be bright.
I am going to try and get an Ohm meter at lunch to test the battery.
I'm not the best at electrical, so any help or ideas in diagnosing the problem would greatly appreciated.
Thanks ahead of time.
Frank
Frank
